Thread: Dimmer switch
Old Oct 5, 2019 | 03:37 PM
DHS's Avatar
DHS
Default Re: Dimmer switch
Gray wire is the dash light power going to the dimmer in the panel, it will work but the VDO gauges will be bright all the time. Just tested that wire the voltage does not change when you twist the dimmer stick. Of course it better than no light in the gauge.
