Old Oct 15, 2019 | 07:16 PM
ala_xfire
Default Re: Baffling Spoiler Problem
The spoiler is merely an indicator of a low voltage problem, either the battery, alternator or high resistance in a connection somewhere.
Check your battery cables, clean battery terminals, check the negative connection to the body on the fender well.
Also buy one of those cheap voltage readouts that go in the lighter socket so you can instantly what the voltage is IF it happens again.
