Old Oct 17, 2019 | 08:22 PM
amx1397
Default Re: Swap a SRT diff into a NA car - Plus LSD
Originally Posted by Turbo-Duck
Thanks, that gels with everything I've seen / read so far. Everything from a SRT6 has bolted on to this car so far (Brakes, Springs, Sway Bars) and I really couldn't detect a difference in the housings. Mine is a 2005 so I'm thinking the axles will work ok.
Have you seen this unit? -> https://www.tractionconcepts.com/2000-2004-Mercedes-Benz-SLK32-AMG-LSD-Kit-p/tcxcmbcus1.htm
It appears that it will work, and they think it will as well. They want to verify some dimensions after I get my hands on the diff before committing.
Thanks again,
-Gary
don't bother with it ,,,unless you have a diff to replace , it will ruin the diff it works on friction, tried one in 2007 lasted 3 weeks had to replace diff. they say it has improved over the years,, how it works , it pushes the spidter gears outward to the center section housing until they lock up .
