Thread: engine quits
Old Oct 17, 2019 | 08:23 PM
canman80's Avatar
canman80
Default Re: engine quits
Originally Posted by tighed1
I'd say three possibilities.
1. Battery.
2. Crankshaft Position Sensor. It will generally throw a fault code. Replace ONLY with BOSCH CPS.
3. Relay Control Module. Check out the "RCM Repair" link in my signature.
Any other symptoms?
Wing stays up?
Radiator fan spins up REALLY fast with the key in the ON position?
Can you hear the fuel pump run for 2 seconds when you first turn the key to the ON position?
Replaced the RCM relay and cured all the engine issues, thanks for the help.
r
