Old Oct 20, 2019 | 08:07 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: Catch Can question
did some googling, seems that anything done to modify the oem pcv is illegal.
That's what the catch can does, but i seriously any inspection station would ping you.
there is a solution that isn't visible. Here's what i did. I took the valve covers off, located the opening into the rebreather covers using an old filter i cut a piece from the old filter to fit the opening and carefully pressed it into place. I used some liquid silicon to make a seal around the edge. Now any splashed oil or crud is picked up by the piece of filter vapors go right through. Voila no oil and crud into the intake, vapors are recycled. Nothing visible!!!.
