Old Oct 22, 2019 | 12:23 PM
g wheels's Avatar
g wheels
Default Re: low pressure tire sensor
Originally Posted by Tbirdtony
Hi everyone,
Like I said in the above post, I am new to a TPM issue. I started the engine twice since I aired up all tires to 33 psi. After the second start the TPM light went out. Maybe the system is working as it should. Only time will tell.
Has anyone seen the procedure listed below? Has anyone completed the procedure to turn off the TPM light? Did it work without affecting any other system on the Crossfire?
https://howtune.com/articles/134-dis...sler-crossfire
It works with no side affects.
I recommend buying an aftermarket TPMS to make the car legal. Draw back is it looks like the on-valve sensor is big and obvious. It will extend beyond the rim and presents an issue if you curb any wheel. The up side is you won't be taking the car to a dealership where you are risking the car in more than one way; including them not being successful. I made the mistake of trying to clone a key at a dealership. They failed and to top it off they left the hood unlatched. I had to stop a quarter mile from their store and latch it back up.
BTW, my 04 is listed as a Base model and it came with the TPMS.
