Brian P
I came across this today and I’m curious if anyone has any experience with this model or others. Basically, you screw the pressure sensors in, calibrate them to the included monitor (after disabling the original system) and you’re done. You can even replace the batteries, so you don’t have to worry about replacing sensors. I appreciate all input.
https://www.amazon.com/dp/B07QYS2J5R..._rROSDbF76CPSQ
I just ordered a set of new wheels. I'm going this route myself. The caps are a little large and extend the valve out. The new cap does change the wheel balance slightly. I'm going to install the shorty 1" valve stems (if that works) and have the wheels balanced with the new caps in place.
