Thread: Steering issue
Old Oct 25, 2019 | 03:13 PM
reb's Avatar
reb
Default Steering issue
The steering seemed a bit on the sloppy side,at 107k replaced wheel bearings, center arm and dampener. Allignment on all four wheels and new Pirellies. When the engine is off the steering wheel can be rotated by a light touch appx throw 2 inches, once the engine is started, the system is pressurized and no play.
Here is where I'm going, when driving I get a drift, depending on the road left or right. I'm thinking a worn steering gear or ... also checked shaft bolts in both locations.Fluid level spot on also.
Would appreciate your thoughts.
