Old Oct 25, 2019 | 09:16 PM
  #6335 (permalink)
manlaw38's Avatar
manlaw38
Wink Re: What did you do to your Crossfire today?
I did a lot!
1) I read that the headlight adjustment bolt can break free of the headlight assembly, and there is an easy fix. I applied the fix and I'm now good to go.
2) I installed seat covers.
3) I removed my fan shroud.
4) I used gasket sealant to glue a HID bulb into the headlight housing since the retainer clip is missing.
5) I realized that I have to remove the exhaust, to remove the starter, to install the Miller flywheel lock, to remove the crank pulley. Hopefully tomorrow I'll have an update of me installing something.
That's what I did today.
Anthony I know this is an old post but may I ask you hot to fix the adjustment bolt mine broke off as well it is so brittle . Thank you
