Re: Another limp along car.
I would suspect the fuel pump before the filter to cause problems, the filter is large and unless you are getting your fuel at some hick garage you should be OK. Environmental concerns have made plastic fuel reservoirs necessary.
Check the fuel pressure or get it checked, I had problems once with an engines performance and it was found to be fuel pressure under 10 psi. A new pump and the problem was solved.
