changing spark plugs
My SRT-6 has 105K on it and I don't believe the plugs have ever been changed. Are there any tricks I should know before doing this? Are there any special concerns about removing the coil packs? Is there a trick to loosening the spark plugs and should I use anti seize on the new ones before installing? I'm a little concerned with them coming loose from the aluminum heads. Is there a trick for removing the plug wires? I've done plugs many times before however not on an SRT-6. Any shared wisdome would be appreciated.
Thanks
