Old Nov 11, 2019 | 11:48 PM
onehundred80
Default Re: changing spark plugs
[QUOTE=manlaw38;932427]
I was commenting on your answer to the OP which is not quite correct on some points.
It appears that anyone who has different ideas to you has to be attacking you personally, not so as the world is made up of people who’s ideas are quite different to you
Point taken !! That's what makes the world an interesting place. We as humans try many things it worked for me. I may not know everything and do not claim to. But my experience with doing what I did did not negatively compromise the cars performance. I did get a throttle body from a 2001 Mercedes V8. E class and in the Spring may try to install it according to your directions. onehundred80 is there a number on the throttle body I should look for. To see if it will work ? Appreciate the positive input. To be honest I have admired your input and read many of your posts and fixed many problems on my car thanks to your posts .thank you !! Seriously. Thank you !! : )
Some PDFs on the new (74 mm) throttle body install.
#1 CLICK
#2 CLICK
