Old Nov 20, 2019 | 08:50 PM
amx1397
Default Re: rear subframe bushings worn/missing
1 remove your wheels,,,,remove brake lines,,,remove EM brake cable,, remove drive shaft , with fork lift under the sub fram remove the SF bolts,, u need tool to remove and reinstall bushings, I made mine out of pipe and plate and thd rod.,BUSHINGS GO IN ONE WAY . u will see what i mean.the little indent ,, some where i posted a thd on removal and ,,install bushings,,and reinstall ,,can't find it not sure this is all but can't think of any thing else.
