Old Nov 22, 2019 | 12:19 PM
zip439's Avatar
zip439
Default Re: SRT6 keeps running when ignition turned off .
I'm not sure exactly where you are in the process, so start from scratch and disconnect battery for a few minutes. While the battery is disconnected be sure the negative cable to the ground is good and clean; both the cable and the connection near the fender. Reconnect battery then try starting the car. What happens?
May actually have problem in the ignition switch/ key. Try contact cleaner?
