Old Nov 26, 2019 | 12:36 AM
Mtnears's Avatar
Mtnears
Default Re: Oil level sensor
Thanks, that is helpful. I'm not dropping a pan for a sensor either, especially when there is a second sensor that shows the level as well.
I can check the oil periodically, not an issue if the oil level is fine.
Next oil change I'll make sure to get a very accurate drain and fill as well so I can be certain things are spot on.
