zip439
Davieboiii, if you where in the US I would suggest contacting Renntech with your question. In Europe someone like Kleemann may be able to definitively answer your question as to ECU tune.
i appriciate your efforts helping me! I dont want to put in alot time into the car if it is not doable.
but ive been told it should work if i connect a megasquirt togeather with ecu. Then the manual transmission will work.
i will try contacting kleeman. But i think more people is active here andcan helpme maybe.
right now the car does not even start up the engine. I put the key to on. And i can see in the RCM box that relay number 2 and 3 is activated. Think it is traction control and engine cobtrol relay. And when i turn it to ignition. Nothing more happends. And i release ignition and want to turn it again it dont work. I have to take key out and insert again to be able to turn to ignition position again.
Dont kblw why engine font get signal and run starter motor abd start engine?
