zip439
Are you aware of the "NO START" problem and cure? There are bad solder joints on the board which will cause the no start.
Click here for details;
RCM repair
Also with the age on these cars the relay contacts get burned and the individual relays can be replaced.
Good Luck.
YES i have already re soldered the 3 solder points. But there was no difference. I also resoldered the rest of the points on the left next to the 3 points. I have also cleaned the relay contacts. So no problem on the contacts. I have engaged them manually to see if they work.
here is a video of what happends when i try to start the car. Maybe you can tell whatncould be wrong.
https://gofile.io/?c=4J8tBO
thanks for all efforts!
