Re: drain from master cylinder with suction gun?
When you push the caliper pistons into the caliper to get them loose it displaces brake fluid in the piston bore into the master cylinder reservoir.
So you drain or suck some brake fluid out so that it does not overflow out the top and make a big mess.
