Old Nov 28, 2019 | 03:13 PM
  #57 (permalink)
wolfstalker's Avatar
wolfstalker
Default Re: Get rid of skreem / security altogether?
My 2005 roadster had this problem, as have many others. The symptom I had is like this: You attempt to start the car. You insert the key and the dash lights come on, but when you turn the key the engine cranks, the motor catches for maybe a second, and it stops. You repeat a second time - same thing. The third time, you turn the key and nothing -
You have SKREEM Module failure.
there is a solution. There is a company called MDP >>www.mdp-services.com
(Mobile Diagnostics & Programming) that can repair your non-functioning SKREEM module and turn this nightmare into a fairly easy repair at a reasonable cost. If you have SKREEM syndrome, you need to contact MDP. (Perhaps others can do this as well - I found and used MDP and it worked perfectly - PLUG & PLAY.
My car sat 13 months while I tried to find a way around this problem - they literally fixed the SKREEM module I removed from my car and sent to them, got it back to me PDQ, and it works.
I am 100% satisfied all the way around, is recommend this as the only solution I know of.
I recommend them 100%.
Here's what I did. I disconnected the battery. (While waiting for your parts to come back from MDP, test the battery, give it a slow charge, test again. If it is "iffy" I would put in a new one) I pulled the SKREEM module from behind the dash instrument cluster - there is an excellent video on the needswings.com website that shows how to do this. I pulled the ECM from under the hood, located in the box next to the battery. I mailed the SKREEM module, the ECM and my key fobs (both mine were working and would open doors, etc.) to MDP in Pinellas Park, FL with the necessary documents and form you can download from their website. They got it in two days, and on the third day called to let me know it was repaired, tested in their test cars, and ready to ship back.
They will then ask for the credit card to pay for the repair. Mine was $450.
I paid postage there, they paid it back to me. If they can't fix yours, they will ship it back to you - no charge for their work, they pay the postage to you. If these terms change.they will notify you when you contact them. If you have key problems, they may be able to do that as well. Ask them.
I have no idea how they do what they do, and I doubt they will tell you.
I wouldn't understand if I knew. I just know it works.
I hope this helps others caught in this situation.
I now have well over 100 starts and a couple hundred miles on the repair, and everything is working as new. This appears to be is a way to repair your malfunctioning SKREEM and use the entire system. I did it, and I'm 100% satisfied. it seems to be a relatively inexpensive way to get a complete fix, quickly. There may be other companies out there that do this - but MDP is as close as your local post office or UPS store.
