Thread: Removing BCM???
Old Dec 6, 2019 | 09:48 PM
zip439's Avatar
zip439
Default Re: Removing BCM?????
From other threads I see you have a roadster. The BCM has several numbers on it. You will see not only a part number ( important as to roadster vice coupe) but also hardware and software numbers. To be certain the new BCM will work for you ALL the numbers must be the same.Try the one you have, but if there is a problem, you will have to seek out another BCM with the exact numbers. Good Luck
