Old Aug 31, 2006 | 07:44 PM
ben47's Avatar
ben47
Default Re: Cupholder - what should i do?
Originally Posted by former NXMX5
Technical Service Bulletin -- its basically a step below a recall. they put out a warning that bad things might happen if you don't get it fixed.
I have to disagree with you. A technical service bulletin (TSB) is not a step below a recall. It is intended to pass on service information to technicians on a problem, what to look for and suggested ways to do a repair if required.. Bad things will not always happen. A TSB will not be performed unless a customer complains about a certain problem that has a TSB published on the subject.
I've seen TSB's on things as mundane as how to care for chrome wheels on up and other minor issues such as the cup holder, so much for being just a step below a recall.
