amx1397
It is your name,,,,,,,,,,OCTANE,,,,,,, or should i say fuel... but before that and most important , what is the afr reading when it cuts out,,,,,,,,,,do you have the factory fuel filter on the car if yes i assume you know it is also a regulator ,,, if you do remove it and put in an adjustable regulator set it for 60 psi ,,it should work.,,
