Thread: Oil leaking...
Old Dec 28, 2019 | 11:02 PM
GraphiteGhost
Default Re: Oil leaking....
Originally Posted by sunsetseeker
The fluid is coming from a 3/8" ID rubber hose that exits right behind the tire. The fluid appears to be motor oil? Not sure where the line is coming from. I will need to pull that panel and maybe the rear wheel. It hasn't leaked much and has appeared to have stopped. I can't see any top cylinders leaking and the top works fine.
Passenger side behind the tire? The drain for the gas cap area empties right behind the right rear tire.
