Old Jan 5, 2020 | 11:55 PM
onehundred80
Default Re: Are stock air filters backasswards?
Originally Posted by Old phart phred
Changed my engine air filters last night, took the old mann ones out and popped in new stp filter in the same direction. Today I was cleaning up and picked up the old fillters to throw in the trash. I notice the clean engine side of the filter pleats while under vacuum would collaspe the pleats against each other reducing surface area and airflow instead of expanding pleats to promote airflow. The Mann filter had a perpendicular support ribs to HELP prevent this, but I didn't check the STP fillter for the ribs. Also the pleats partially block intake airflow on the dirty side. Is this how needswings cai intake improves airflows? I am thinking a couple of adapted mass produced air filter housings from the salvage may be better.under the grille, may rival the needswings system. PITA to change. Would require sealing/clamping existing cai intake tubes. Sorry I no longer will ever do the foam or k&n style filter systems.
You are applying airflow and air pressure to the filter backasswards. In practice there is more pressure (ambient) on the outer face than the inner face.
