Old Jan 9, 2020 | 04:35 PM
onehundred80
Default Re: Headlight problem
Originally Posted by NavVet
I bought this SSB Crossfire about a month ago, in really good shape but with a few neglected issues. I've been busy knocking each issue out and have come to my wits end on the headlight aiming issue. I've made sure that each bulb is in proper position inside the housing, made sure the adjustment stem was connected, and still cannot get the light beam to shine but just barely in front of the car, and by that I mean just a few feet. I have searched out and read every post I could find on the subject but still perplexed. Just short of pulling the entire assemblies (don't have a garage and it is winter) I thought I would seek knowledge from the forum. Plan on pulling them anyway when it's warmer because I noticed the projector lenses seem foggy (I imagine they should be crystal clear) and can hopefully be cleaned. Am I missing something? Can the housing be rotated upward by the bottom assembly bolts, cannot tell without laying eyeballs on it? Any suggestion would be welcomed.
To my knowledge, there is no bolt at the bottom of the headlight. It is held in with four bolts, two at the top and two at the bottom. The white adjusting screw does the up and down travel adjustment and both beams move at the same time. There is a horizontal adjustment but that can be forgotten in your case.
You do not say if the high beams are also too low.
I think 90% of the light problems stem from the bulb positioning in the headlight, the tab is at the top for the high beams and at the bottom for the low beams. What seems to be the correct position is often not quite correct, I have had that problem myself.
If the car has had a crash then the whole mounting may be bent, I hope not for your sake.
