NavVet
Thanks for your response. The high beams are shining low as well, they actually make the perfect low beam, I could pull the low beams and use the highs in their place and it would suffice. Would use them anyway but people tend to spaz out when they see 4 bulbs coming at them, even though the low beams are hunting for crawfish. I see no ready evidence of a frontal crash so I hope I'm good there. I will definitely go through everything again just to make sure it all is correctly installed. Thanks for the advice and help.
Have you tried adjusting with the white stemmed adjuster? It has to be able to move the lights and to do this it must be in contact with the nut or whatever inside. Turning it moves the whole light assembly inside up or down. It can come out if contact with the nut but others have just screwed it back into position.
