Old Jan 12, 2020 | 10:46 AM
Tbirdtony's Avatar
Tbirdtony
Default Re: Car Not Turning Over After Reading and Erasing Fault Codes
SrWilliams, I had the same problem a month ago. All dash lights worked normal but when I turned the key to start there was nothing (the engine did not turn over). My problem turned out to be a bad battery. My battery passed the load test at AutoZone but the readout said that the battery had only 50% capacity. AutoZone put it on their charger for 45 minutes and the battery passed the load test again but still the readout said that the battery had only 50% capacity. I tried the charged battery and the engine still didn't turn over. I purchased a new battery and the engine started right up and everything has been fine since. You may only have a bad battery. Get it checked. Hope this info helps.
