Re: Strange noise.
You will need to remove the wipers ( may need a puller ), then the the wiper cowl.
Located about in the center is the alarm module, unplug and remove.
You can either go on without an alarm or order a new replacement.
Search on here for "alarm" for the MB part number.
( clean out all the leaf debris while you are in there, check the drains are not clogged )
