doesterly
I bought an SRT-6 that the prior owner had replaced the supercharger pulley on. I found that this pulley had a crack in it, so I bought and installed my own replacement pulley. The one that I put on was a Eurocharged 62mm. When I am driving the car normally, or even a little aggressively, it runs through the gears as you would expect. When I do a standing start with the accelerator to the floor, it gets almost to the end of first gear, stalls briefly, shifts to second, then runs through the rest of the gears with no issue. If I turn off the electronic stability program (ESP) and do the accelerator to the floor standing start, it will run through all the gears without stalling. Of course it smokes the tires without the ESP, so I would like to be able to launch with the ESP turned on as well. Thoughts?
Thoughts? Get rid of the 62mm pulley, they blow-up and cause damage $$$$$. Is it steel or aluminum? I do not think they make it anymore. That pulley needs fuel mods to save damaging the engine if it is not already done.
I do know too much about it only what I have said.
