Old Jan 17, 2020 | 10:41 PM
IB JT's Avatar
IB JT
IB Staff
Default Re: Trying to modify my threads (3) on Double Din install
This problem only applies to long posts, short posts are OK. On long posts I can only see the attachments which are in the normal layout.
When I hit ‘source’ in long posts I only see what I take to be code inter spaced with my original text and I cannot figure out what it actually what the code says.
@onehundred80 this issue appears to be related to your signature issue. It's due to the size tag usage as it's not fully supported. I also see a similar issue where the HTML tags are stacked, such as the case with your signature, but the real issue is the size tags aren't fully supported and they're breaking the What You See Is What You Get Editor.
Like I said in your Signature thread, I'll check with the team on Monday to see what the thoughts are about the size tag issue.
Thanks.
