GraphiteGhost
PT - Cruisfire. Buying this car with all these 'problems' and trusting someone else's description, is just asking for trouble. If I have read this post correctly, you should walk, NO RUN, away from buying this car. IF you already spent the $, I hope you get some great help HERE in this forum before you take it anywhere. The regulars here all suggest you NEVER take it to a STEALERSHIP (what we call Chryslers tech service on this car). Good luck!
Graphite, I have a 2005 rebuilder, with a damaged: Hood, Front bumper, Driver's side headlight, and the lower passenger side grill insert, + a bit of miscellaneous other things. The "parts car has the same color hood in excellent condition, the driver's side headlight is good condition as well as some of the miscellaneous items I need. It also is equipped with the OEM fixed rear spoiler. The price I am getting it for is about $500.00 more than what I could buy the hood and headlight for. If the problem is the ignition switch housing part# 68001655AB then I think I could turn a buck or two if not more. Or I could source a few more parts and rebuild it for sale complete.
