Old Jan 23, 2020 | 08:39 PM
onehundred80
Default Re: I need help fixing rear rotors with locked up calipers
Originally Posted by psuperti
I need help I let a total stranger who self proclaimed to be a certified mechanic do the rear amg c32 upgrade. What would cause the calipers to grab the rotors so tight and never release? The actual caliper is against the rotors metal to metal with the pads now damaged as I see little shards of metal. I Drove 3 feet before noticing this.
During the installation my 1st observation while i was installing the new wing, i noticed he let the fluid level drop to the bottom of the reservoir. 2nd no bolt on the rotors to hold it in place. 3rd he was trying to get the pads to give him more space for the rotors with a metal tip of a screwdriver driver.
I left for 30 min to get more bottles of Motul 600 I come back the car is not drivable. I attempted to bleed the brakes alone and lost light quickly and had to stop.
Thx
Rotor
This is the caliper c32 AMG rear
What size rotor are you using, thickness and diameter? Spacers?
Do they fit the NA as well as the SRT.
NA rotors are smaller than the SRT rotors, so maybe the bolt holes for the calipers are closer to the axis of the rotor.
The caliper looks too close to the hub and causes it to rub, the offset appears to be incorrect.
