TheStig
have you discovered the issue? I am having the same problem. the driver side headlight has been replaced before I bought the car and I adjusted it no problem. the passenger side was adjusted just fine until the other day I screwed up and let the hood slam shut very hard cause my stupid hood strut doesn't work right. now the passenger side light points down, it will adjust but not near high enough
Sounds like the adjusting rod got knocked loose when the hood fell, don't know for sure but possible. I found mine was disconnected and posted a fix,
https://www.crossfireforum.org/forum...ht-aiming.html Good luck to you.
