Re: 2004 Crossfire Electrical Issue
pizzaguy,
The starter does not engage.
After reading the posts in the SKREEM section I have gathered the following items to check. 1. check for water in the lower trunk, remove the foam liner. 2. Disconnect the battery, disengage the Siren Alarm in the Cowel, remove Fuse 9 inside the driver's door fuse box and reconnect the battery. Am I correct with the location of Fuse 9?
Thank you for the additional information.
franklindm
