Re: Worlds Cheapest V8 Swap
Also the drive train is almost ok the srt6 drivetrain will work without a problem the limited drive shaft I can not say , the axles are the same as srt,,,, the rear end is the same as the srt ,,, the limited drive shaft uses a smaller yoke 3 bolt on each end for non racing it should be ok. the yoke for a limited ( center to center) is 3.5" for the srt it is 3.75"
in the transmission the limited is weeker than the srt and the srt is weeker than the V8 if you have your limited tranny rebuilt with the 772-???? V8 kit ,it would be the same as a v8 along with adding the blut tops. yet for street driving the limited tranny will work fine.
