phil alvirez
lets see: seems to me that there are 2 ways we can use your module:
1-to plug it into the circuit so it replaces the stock immobilizer, and:
If your Skreem already works this would the way to go.
phil alvirez
l
2-to keep as a spare in case the stock fails, so we can plug it in. sort of spare tire.
Of course you can do it that way with my preprogrammed EEPROMs but then you have to let progamm your PCM so that it accept this codes.
phil alvirez
l
then, how this connection would be? (i imagine sort of connector hidden but easily reached)
what we have to do in advance to be prepared? (like what we have to open/cut/solder)
details?
That is the hardest thing I am working on. I found out, that the big plug is from TE Electronics but Daimler has there Hands on it and they can't give any Information about that. But this doesn't matter because you can buy them from Mercedes a little pricey but you get them. But the other side where you plug this in is a whole part of the skreem module and that you doesn't get to buy. Maybe someone here has connections to TE Elektronics, they have similar plugs listed and I buy also one set, but the Mercedes plug don't fit.
I think I have to buy all used Skreem modules... The advantage would be that I'd have also the right case, but I'd have to solder everything off and on... a lot of manual work.
