Old Feb 13, 2020 | 09:41 PM
GraphiteGhost
Default Re: Possible Water Pump Replacement
Water pump, probability @ 99.999%. When you replace, be CERTAIN to follow the hints from those who have done the replacement in the past. TRACK EVERY BOLT using a template, as you remove put bolt in template continuing on until pump is out. Then, put new pump in following the correct bolt in correct hole. The bolts are of differing lengths, so take the advice of those past, and be careful. I am sure you know this but just in case.
