Old Feb 15, 2020 | 03:27 PM
Oldschool's Avatar
Oldschool
Default Re: Factory wheel size
Originally Posted by andrew
here you go ~ the specs are correct...
Front ... Rear
Wheel Size: 18 x 7.5 ... 19 x 9
Bolt Pattern: 5 x 112 mm ... 5 x 112 mm
Offset: ET 35 mm ... ET 35 mm
Center Bore Dim: 66.5 ... 66.5
Tire Size: 225/40/18 ... 255/35/19
I KNOW THIS IS AN OLD THREAD BUT........... Has anyone put on 19" rims on the front along with 19" on the back? I found some must have aftermarket"s but not available in 18". Thinking a front wheel size 19 x 7.5 coupled with maybe a tire size 225/35 R19 could work? any suggestions?
