Old Feb 16, 2020 | 02:40 PM
GraphiteGhost
Default Re: battery for alarm
Originally Posted by phil alvirez
the battery that i recall comes with the alarm is this: https://www.amazon.com/VARTA-5561560...VC4YZWSZVENA5H
so i may get it instead, as it is available.
Just a suggestion, IF you have an OEM siren (maybe not), make sure before you buy the type of batteries (yes 2 IF they are the 3.6v ones) you need. Newer sirens that work in the crossfire have a (only one) 4.8v battery inside. You have to determine they type and voltage battery in YOUR specific siren. Otherwise, you'll be stocking up on batteries you may never use/need.
