Speedy4x4
Is common on a m112.
did it go away after warmed up, sounds alittle more aggressive than others from video.
Mine did it when i 1st got it, warmed up it went away, fresh oil change and went away, i have not changed mine, and i bought with 50k and i have 189k atm.
did you let it run, or shut it off when you heard the sound ?
And reccomend oil is 0w40, Mobil 1 synthetic is what I use, about $25 for 5 at jug at walmart.
What the sound, sounds like to me.
You can go to a autoparts store and get a mechanic's stethoscope and poke around where the noise is coming from, to help you pin point.
Car was on for about 3 mins and then the sound started. I didn't let it run much longer after that. I guess I can let it run longer to see if it stops. Or maybe drive around a bit and see then. Just don't want to damage anything.
I'm gonna change the oil myself and see how it reacts. And thanks, I'll get 0w40 Mobil 1. Again...its weird. Really sounds like a taser popping...
