Old Feb 20, 2020 | 04:11 PM
nobodysprisoner's Avatar
nobodysprisoner
Default Re: Another No Start...But different :)
Here are some pictures of the sensor data from the pcm and skreem module.
Again, the things that stand out to me are the ignition angle which was -3 degs or so when it was running and the temp sensors for the airflow sensor being too high(was about 30degs outside at the time). Also it shows the cat temp at 300deg and since its been sitting that cant be right if thats what its saying. Let me know if you guys spot anything else that might help.
Using the drb3, I am unable to actually find anywhere where it says if the rolling key codes match from the skreem and pcm. It shows the transmittor for the remote lock/unlock but thats all I see.
Also in the pcm sensor data there is a value called S/C state. Does anyone know what that is referring to?
