Originally Posted by SLKGHOST
New here and loving this forum.
Unless someone is racing professionally, like this HDDP, who needs this "rocket fuel" for the street? Last time i checked racing was illegal on the streets.
Anyway YOUR rocket fuel recipe will be a weekend project when i make a run over to Vegas. I will test it out in the crossfire before dumping it into the SLKs (320 & 350) we have.
Does HDDP have the engine modified to accept this custom fuel? if not, i will not worry about blowing o-rings and gaskets on mine.
I have the engine modified, but not specifically to run the juiced-up fuel. You can run this formula with a OEM engine / ECU. Don't use it just to impress your friends when you're driving around town. It's way too expensive and would be a waste of money... The Propylene Oxide is about $250 for five gallons.
If you're doing drags, I'll bet you can shave a half second with this... Make sure you do the mixture properly and account for the gas already in your tank.
