In your shifter there is a little trap door you can insert a screwdriver into so you can move the shifter in an emergency situation or complete loss of battery power. It is to the rear of the "D". Pictures are below.
As for the secondary air injection, it's typically a bad relay or a good relay with dirty contacts in the Relay Control Module. Fairly simple to clean if you are handy.
Jared
