cincinattirick
I own a 2008 Crossfire hard top. It has 28,000 miles. I live in Ft. Lauderdale, Fl. When I turn the A/C on heat pours from the vents. Seems to be stuck in that configuration. I don't really use the heat. The A/C has been ice cold up to now! Any suggestions!
Check the two heater valves close to the battery these should shut off when the coolest temp is selected. If the hoses are warm after the valve on the bulkhead side they are at fault.
