Re: What did you do to your Crossfire today?
Johnny Versatile
Added the secondary ground strap to the rear of the bell housing, direct to the battery as per the Forum recommendation. Bought a 36 inch eye to eye 4 ga strap and put a wire loom around it. I like to make everything neat and look factory if it isn't. Put the loom on it before you install it as it is a little tricky around the exhaust and heat shield. Pretty cheap insurance for our electrically sensitive toys. Only an hour and that included the coffee break.
What's the lug size on both ends? 3/8" or 5/16"? 8mm or 10mm?
