jdorn001
Update - we followed the throttle reset steps, and the response is all good ... will have the code for this checked when it stops raining ...
IF all is good, wait for a couple of start/stop cycles over a couple of days (don't rush it). It takes a couple (or more) cycles to clear its fault codes depending on the codes and why they were set. If you think every burp is a problem, you'll continue to do this or that and cost you a lot of $. Also, you posted another post about the same thing, please limit your post to one issue at a time (even if it seems this issue is solved) until a reasonable amout of time has passed. Contact a moderator to close/lock the second original post you posted with the same issue.
