Old Mar 14, 2020 | 10:57 PM
KnightRyder_77's Avatar
KnightRyder_77
Banned
Default Re: New to forum looking to buy '04 crossfire
Originally Posted by JoeO
Only thing that I would have done different is have my mechanic check before making offer.......But at 158k, I would :
go thru test ALL fluids and check all connected hoses (for replacement if needed)
check brakes and suspension ..........could have needs in front and back.
compression check very important
Check serpentine belt
Battery check.....Crossfire has lots of power requirements, don’t go more than 5 years even if it tests fine
Knowing all the above, at best, you wont be caught off guard.
if car still seems solid you have bought a well built machine for 2,600. Spend time here learning solutions to the 3 to 5 problems and throw your worries away.
best of luck and lots of curves,
Joe
Joe so I wanted to share with an.update.
The serpentine belt.has been replaced as of last year also the Idler Pulley has been changed. Also I have been able to.check the brakes front and back and the look like have lots.of padding left..took her out again tonight for a night ride and once again the brake check solid. And the steering was solid no noise turning the wheel..did 2 hard left and right turns to hear how things sound it all sounded great.also checked the oil before start and it was perfect. My only out side damage is as.pic shows. Just wanted to share with you
