Old Mar 18, 2020 | 03:58 PM
  #41 (permalink)
amx1397
Default Re: Driveline thump solved
Originally Posted by 93Snake
The Chrysler dealership is telling me that our carrier bearing is bad and needs replaced. The quote they gave me was $2100 "because it is all together and they can't just order the bearing". Is this something that could be handled at home or am I better off buying the part myself and having a shop do the work?
forget everything you just said go to needswings.com order the bearing ,,remove your drive shaft,,,,,,, with your hands (no tools needed replace the centerdriveshaft beaeing and boot),,,,,,, the drive shaft has notches on it for alinement and balance put every thing back together..
https://www.crossfireforum.org/forum...ght=driveshaft
