Thread: No high beams
Old Mar 19, 2020 | 10:26 AM
Oldschool's Avatar
Oldschool
Default Re: No high beams
Check out this link https://www.pelicanparts.com/techart...el_Removal.htm
and this one https://www.pelicanparts.com/techart...eplacement.htm
You need not remove the hood release or the plug-in from the trim panel; just let it hang (picture #10 and #11)
There are other links on this site to R and R this switch ... I felt warm and fuzzy using these two links and printing out the pictures for reference as I progressed.
One further note: The yellow air bag plug just pries out from the silver mount (picture #3).
I had to use an air impact to remove the 10mm allen bolt at the steering wheel (rent an electric one if you have no access).
This was a bit out of my wheel house. I wanted to use a NEW switch so I would not have any issue with a possible used bad switch.
