Old Mar 20, 2020 | 07:38 AM
  #132 (permalink)
phil alvirez's Avatar
phil alvirez
Default Re: I hacked the Skreem, the Skreemulator
we know that the immobilizer can be deleted. the statement by Precision ECU tells that they already do it.
it is done:
"This, immobilizer delete service will delete the immobilizer (SKREEM) function in the ECM making it functional without immobilizer (SKREEM) input.The ECM will be Plug n' Drive and will require no additional programming. Original and any keys will work. Simply install the ECU and start the car. For this service, you will have to send in the ECM (original or replacement) and SKREEM module. " (and, by the way, nobody else provides so much detail on what and how they do what they do-and nobody else claims that can delete it)
so, if they already are doing it, means that there is a way.
it is a matter of time that fellows like Andre will learn how to do it, be same way as Precision ECU is doing, or other way.
so it is not a matter of if, but when.
https://www.ebay.ca/itm/2004-2008-Ch...gAAOSw791ebTCR
